Error 105
druhe
Southwest Pa
I just made the switch to ScannerCast. I am receiving the following error
Scannercast PUSH Error 105
The program says that it's running, but when I check the status it says I am not connected.
Any assistance appreciated
PeterGV
K1PGV
Mont Vernon, NH
"PUSH Error 105" means that ScannerCast is getting an authorization error when attempting to log your feed onto RR.
HEY! Seems that you got it fixed, because your feed is running fine and it IS running ScannerCast! Excellent!
Sounds good... my only suggestion would be to turn down the volume about 30% on your scanner. Your audio is clipping quite a bit. I know, I know... ScannerCast needs a VU meter.
Peter
K1PGV
