Error code 4
thinder
Silverdale WA
Hi. Would anyone know what error code 4 is. I have 3 feeds down says "unable to connect error code 4" Able to surf web on all 3 computers but lost all 3 feeds at once. Im stumped. Thanks for any help....
ProScan
Software Provider
Ontario, Calif.
It sounds like you are using my ProScan or Free RadioFeed program Source Client feature.
Any error code means that the source can't communicate with the far end. The TCP protocol doesn't indicate where the problem is. It could be the computer, router, cables, ISP, & far end. The computers can be eliminated since it's happening on 3 computers.
I would first power cycle the router. If that doesn't cure the problem then reseat the Ethernet cables. I've seen some use a program called PingPlotter to narrow in on the problem.
thinder
Silverdale WA
Thank You for info. I am using Pro Scan. I did power cycle modem/router. I do have spare modem/router combo. I will replace and see if that helps. Thanks again....
thinder
Silverdale WA
Im back on the Broadcastify server. Thank You for the help. Replaced my router and that solved it. Thanks for great software,very user friendly..Thanks again, Tim...
