Error code help
ozzie
mn.
Am unable to read or write a xtl2500 radio. Keep getting this error code.
Radio failed to acknowledge.
Error context 24.
Status c0000386.
Not sure if this is an cps problem or a computer problem.
Will001
Pine Ridge, SC
Had the same issue with Astro 25 CPS... just try other COM ports on your computer, and if that doesn't work, restart your computer and give it a 5-10 minute break ;)
sfd119
Error context 24.
Status c0000386.
You're not communicating with the radio. You either do not have the right serial/USB port, driver issues, CPS issues, or radio issues.
To rule out the radio, make sure you try it with a known good cable on a good computer that has worked in the past.
ozzie
mn.
I may have a broken wire in the cable. Will try a usb cable.
