ERROR CODE
longie
Long Beach, CA
I've been using my G5 for a few weeks now and every once in a while the following Error notice shows up; Red X on top
System not working correctly
1. Please press RESET+DVR+ PLAY key for 3 seconds to manually reset
2. The contact Unication with your error code (Error#ffffa)
It eventually goes away and my radio works fine.
GTO_04
Noblesville, IN
I have also found that just powering down and then back on again will make that error code goes away. I have only had it happen twice.
GTO_04
tp3244
This topic comes up all the time. I actually think it is just a symptom of "not great" firmware that occasionally just doesn't start up and occasionally needs a "do-over". A battery pull shouldn't be necessary - I'm pretty sure doing the RESET+DVR+ PLAY does the same thing...
The good news is this is only on startup and never after things are up and running.
IAmSixNine
Dallas, TX
I have not had that error in almost 2 years. I never was able to get the 3 button reset to work and relied upon battery pull.
Can you confirm for us what version of firmware is in the unit and what version of PPS you are using.
N6ML
What firmware version? Not sure what 5.5 would be. The current public firmware release is V1.20.
N6ML
You should upgrade to V1.20. If the problem persists after that, your dealer should be able to help you open a support case.
