Error in PSR-500 pre-loaded data
rdballenger
In the preloaded V-scanner data, the DC 800 MHz system has custom tables designated. Instead, the trunking tables should be set to standard. It is the DC 450 MHz system that uses the custom tables.
doctordave
How does the 500 sound on the DC trunked systems so far? Do you have any other radios (Unidens or prior GREs) to compare against for quality of sound & frequency of any decoding problems?
