Error Loading Mp3
KB0VWG
Lyford, Texas
I have the scanner connected to the line in on back of my pc, Scanner cast is running but i dont have any audio and the feed says it still offline. I am using a mono cable from scanner to pc. I have the mp3 bitrate set to 16 bits/seconds. The server port is set on 5700 do I need to change that or leave it at default. Does the max clients need to be set to any number?
Thanks for any help.
Michael
kb0vwg
hvscan
Hudson Valley, NY
Wirelessly posted (BlackBerry9530/5.0.0.328 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Have you configured SC through RR/Icecast setup?
dwh367
Owensboro, KY (Daviess County)
Stream itself seems to be working okay but the audio level sounds like it's a little too hot. The clipping is making it hard to understand what they are saying.
KB0VWG
Lyford, Texas
Thanks for the reply
I figured what i was doing wrong I overlooked a couple things that I needed to fill out, Is the audio better now it seems better to me. Feedback is appreciated.
73s
Michael
