Error message when copying
triumph
Hi
trying to read from the SD card to EZ scan with the PC card reader I get an error message "Value must be between 1 and 2147483647" and stops. Have to use taskmaster to get out of EZscan. Sure I have seen reference to this somewhere on the forum but cant find it. Any help please.
Barry G6SRE
buddrousa
To help get your answer we need more info.
#1 What scanner are you using.
#2 What version firmware is in the scanner.
#3 What version EZSCAN are you trying to use.
#4 What release version is your EZSCAN.
triumph
Scanner is TRX-2
firmware is the one before the update yesterday
EZ scan is updated today to 3.5
triumph
Just done a bit more investigation. Copy stops at TS000009 and when I try copy to from the SD car a new folder I get a message that TS000009-PD is corrupt.
triumph
Thanks Mike had a look at that so have deleted all my trunk systems and hope that will do it. Not had time to try copying to EZ scan yet as have to go out
Barry
