DSDPlus Errors on a P25 system DSD+ Fastlane
LD723
On a P25 trunked system I listen to which is the CoMIRS system for Massachusetts there is a non simulcast site (wilbraham) that I listen to which generates random errors on the voice channels and cc channels when decoding live from tcp FMP24 at random times. When I recorded the raw audio for the cc and voice channels when the random errors appeared I decoded them and I was able to hear the audio crystal clear with no errors so it seems to be a problem with live decoding and I had the same results when I tested with unitrunker and vb cable instead of the tcp linking. The issue is mysterious because the signal does not drop ever since the transmitter is not to far from me and messing with the gain did not affect anything at all.
