ESN number
I need to recover my ESN NUMBER I recently programmed a Harris 7100ip radio and while writing a new DSP to it I screwed up and out the wrong feature string days in it I plan on contacting Harris TAC. But I need to recover the ESN in order to do that. Any help will be greatly appreciated.
Radioman96p71
Polk County, IA
If you can read the radio with RadioMaint, you can read the tracking data out and click either the Feature Data Edit button or Radio Status button to get your ESN.
Good luck.
Thank you for your answer I was able to pull the radio status. Is the ESN number called something else in the radio status information?
Radioman96p71
Polk County, IA
I don't have RPM on this machine but i think its called Serial Number or something similar.
Here is a picture of the screen in RadioMaint.
The field you want is ROM Serial # down at the bottom. Obviously yours will be different than the above example.
