Essex County Fire LTR Passport
TD
Hasting County
Hello All
Does anybody no what system Essex County Fire has switched too. Because on the site it's says system is deprecated?
TD
mciupa
Moderator
I believe they are using DMR now. You will need to run DSD+ and decode the voice channels from these sites from the TURBO CONNECT Network:
Code:
Site
033 	Town of Essex	01 420.15000c 	02 420.35000 	03 420.45000 	04 420.65000
034 	Tecumseh		01 420.73750c 	02 420.83750 	03 420.93750
035 	Belle River		01 420.71250c 	02 420.81250 	03 420.91250
Not easy, but not impossible.
I notice you have some older scanners, I use a Pro-2032 with a discriminator tap and run DSD+ to listen to DMR. Hopefully you could sacrifice one of those for a modification and you could be listening for only a few bucks in parts. :)
TD
Hasting County
Do you have instruction on what ya have to do for this modification. Or where can I get the instruction and what parts are needed?
Muxlow
Super Secret
Middlesex County
mciupa
Moderator
If you want to mod the Pro-2036...
I have a link that shows pictures:
Discriminator Output COM215
Once you have that part done, you can feed it through the DSD software. :cool:
tilt404
Canada
I'm on the detroit river in Windsor but still get Leamington, Kingsville and LaSalle fire very well from where I am on the conventional frequencies listed on RR. So the signals cross the county from one side to the other nicely thankfully.
Some dispatch is from Windsor and LaSalle which helps. I keep the input in for Leamington Fire 164.085 156.7pl for the times the 154.010 isn't quite coming in. So at least I hear the dispatch like now with a accident that happened in Leamington a little while ago which Kingsville also responded to.
Essex County, Ontario (ON) Scanner Frequencies and Radio Frequency Reference
