essex county ny
Blindman
plattsburgh ny
I'm writing this in hopes of finding out what the actual frequencies are or will be for the essex county e911 system, after googling for some time , I have found nothing concrete, even the uls search had only something that might or might not be those channels.
58006
NY DB Admin
Washington County, NY
MegaHertz315
Central/Upstate NY
WQLI541
8K10F1E emissions
P25 Digital Conventional Multicast. No trunking.
151.0850
151.1000
151.3025
151.3400
151.3550
153.7550
153.7775
153.8450
154.1000
154.1450
155.2950
156.1200
156.1350
156.2100
156.2250
158.7900
158.8500
158.9100
159.0450
159.1800
Plug them into your DIGITAL scanner and let us all (and the database) know what you come up with.
Blindman
plattsburgh ny
WQLI541
8K10F1E emissions
151.0850
151.1000
151.3025
151.3400
151.3550
153.7550
153.7775
153.8450
154.1000
154.1450
155.2950- old vhf hi cvph
156.1200
156.1350
156.2100- old clinton county and essex co sherrif, now used at clinton county jail
156.2250
158.7900- plattsburgh city police repeater input
158.8500- input to 156.21 clinton county jail
158.9100
159.0450
159.1800
It may be that I am too far north, Im hoping thats not the case, Ive had fairly decent luck with some essex county stuff in Plattsburgh, I have a rooftop antenna and a pro 106 , I do get the occasional bleedover from a paging system on 152.48 though.
MB
North East N.Y.
It also uses a combination of frequencies from callsign WQQH430. Only 4 out of 6 sites are currently up and testing is in the initial stages. Because of the rugged mountainous terrain of the Adirondacks and the limited sites they could obtain due to Adirondack Park Agency permitting they had to go with a conventional Multicast system to provide the coverage they need with the budget they had. Simulcast or Trunking will not work in the Adirondacks without a ton of sites. If you are receiving Essex County stuff in Plattsburgh now then you should receive the new system even better because they are using many more sites then they use currently.
I was hearing sheriff on astro
151.3025 nac 281
156.2100 nac 281
156.1350 nac 281
then fire was on new system testing in Willsboro point on active investigation
154.1450 nac 281
getting dot occasionally on
151.085 nac 281 - 282
then past 3 days NOTHING at all.
anyone else heard anything in the last few days? thanks
also 156.1350 nac 282 and 283 were running encryption for 3 days then whole system went silent for the past week no hits what so ever only analog sheriff on 156.21 114.8pl
not even picking up lo-band at all and I now theres been calls going out and I am receiving about the same as MB does just hes delayed to me about 10 seconds or so.... also he had a loband page today and I didn't receive it
state polce are also seeming like they are running on low power
any info would be great help... is it possible gore or the keene quad and whiteface are all currently down?
only other thing I have done is installed a par vhf-fm filter tuned to 96.3 fm to knock out local npr...
but even unhooking the par filter does not restore reception
just had a close call hit on
151.8650 nac 717
but I believe its encrypted just heard about 10 hits but its chirps high pitched and no audio to verify whom it might be but in Keene ny it was full scale with att on
However at that time there was a DEC ranger truck pulling into stewarts so it is possibly forest ranger
Essex County dispatch is using 156.135 p25 mode for main dispatch with nac 281 282 283 and 284
Fire dispatch is 154.145 mixed pl 110.9 and nac 281 282 283 284
Note most transmissions are still in analog on 46.32 46.44 and 46.32 for dispatching on low band.. some departments like mineville witherbee are on the new system...
will post more as they sarts coming in also sheriff car to car uses nac 812 on 156.135 and 158.85 with some e3ncryption but most are in the clear...
Note most transmissions are still in analog on 46.32 46.44 for dispatching on low band.. some departments like mineville witherbee are on the new system...
will post more as they sarts coming in also sheriff car to car uses nac 812 on 156.135 and 158.85 with some encryption but most are in the clear...
and 46.46
mfdbenji
Vermont
154.145 NAC 282 was active last night for a fire in Willsboro, seemed to be Dispatch to Apparatus use on that channel. I was not able to receive any of the fireground tactical channels for the incident last night.
Monitoring from Rutland VT
157.2525 - - N 283 - 13-20-27 - Essex County Fireground simulcast on 46.22 analog
154.1000 - - N 283 - 13-21-16 - EMS Tac
154.1450 - - N 254 - 17-08-05 - UNKNOWN CLOSE CALL HIT in KEENE NY
depends on what tower/site you are picking it up from... im getting mostly whiteface and gore...
heres more on the updates...
154.145 nac 281 282 283 284 is Essex county New York fire repeater
156.135 nac 281 282 283 284 is Essex county New York EMS repeater
156.21 nac 281 282 283 284 is Essex county New York sheriff repeater
151.3025 nac 281 282 283 284 is also Essex county New York sheriff Repeater
154.1 nac 281 282 283 284 is Essex County New York Fire repeater 2
151.085 nac 281 282 283 284 is Essex county DOT
wqli541 but my submission is still opened if anyone else can also verify these and submit them
the p25 listings for Ticonderoga are wrong as well as the 156.135 for sheriff is wrong also heres the list of what I have found and yes this system is in use also for the past 3 months now
alongside the old paging loband frequencies and the analog high band... both systems are used simultaniously
