Estimating (Very Roughly) Coverage Area
Dave_D
Incline Village, NV
Hi all,
Is there a general-purpose chart or formula for the coverage area of a system, given the transmitter's power and frequency? Forget geography, obstructions, sun spots, etc. I'm just looking for the estimated working range of a system. [Per my previous threads, I'm mapping systems by lat/long and radius into my GPS-aware scanner.]
Most of the systems I'm mapping operate in the 800 Mhz spectrum and employ a 100 watt transmitter. Do I tell the scanner that this system has a 10, 20, 30 or 50 mile radius?
Thank you!
Dave
n4voxgill
Silent Key
New Braunfels, TX
10 should give you a good signal. 20 will drop out if you get behind a hill or obstruction. 30 is not realistic, but you may get some signal. FCC limits most systems to a weak signal 3 miles beyond the city limits.
N
N_Jay
Guest
Good rougth estimate (given the sparce information)
However the 3 mile rule is only for NPSPAC 800 MHz channels.
R
Rayjk110
Guest
150 MHZ at 100w, depending on height, can cover a whole county. It does over here. Actually our local FD Gets interference from a FD 1 county down on a 90w repeater ontop of a building on the same freq.
There was a formula running around, I think its was something like antenna height times distance to horizon plus .5. I don't quite remember....
Al42
Long Island, NY, USA
Horizon (in miles) = sqr(antenna height in feet) * 1.17.
Signals tend to go farther than the horizon (knife-edge refraction, reflection) and less than the horizon (path loss, obstructions), but adding the horizon distance of the two antennas (receiving and transmitting) gets you, if not in the ballpark, at least in the same zip code.
