westsdad
Anyone get Etrunker with ESK to control a second tracking / voice scanner?
I can get Etrunker (w/o ESK) to work using a single com port and two com ports to control a second tracking / voice scanner on two different computers.
When I try Etrunker with ESK, the second scanner drops out of VCO mode and doesn't display the parked frequency. I cannot get Etrunker with ESK to control the second tracking / voice scanner using a single com port or two com ports on two different scanners. Etrunker with ESK will properly track the system -- it just won't control the second scanner so there is no audio.
I'm trying to listen to the Lakewood, CO EDACS TRS that recently turned on ESK. Awaiting a firmware upgrade for the BC15T / BCD396T // BCD996T. Will have to get a PSR-600 if the firmware upgrade either doesn't happen or takes too long.
I downloaded the Etrunker with ESK from the RR Wiki. Is there a different version than v3.9.0?
Thanks,
Scott
Thanks,
Scott
