The link was active for a little bit last night. But is off line again. The link will be up and running full time in about a week give or take a few days. What about the scan list that i wrote out is that one ok, or should some tlk grps be changed. yeah i understand its a busy system, but its Austin. Like i said i am going to break down each link into sub links, but for right know there will only be two links. The second link will only run at certain times. As for as big events i understand that i wont be able to stop on tlk grp evertime something big is happening but i will try to. That is why it is important for everyones input on how i set up this link and what channels to scan. If there other people in this area that would be willing to set up a link also that would be great. But like i said any and all input is more than welcomed.
Here is my view on the EMS side about channels to have. I'm part of the ATCEMS system as a paid/volunteer EMT-B and I listen to it quite frequently.
TCEMS CONTRL EMS Dispatch
TCEMS MCOM N EMS MedCom North
TCEMS MCOM C EMS MedCom Central
TCEMS MCOM S EMS Medcom South
TCEMS MCOM W EMS MedCom West
TCEMS CMD1 EMS Command 1 -Don't need, never heard it used in 4 years....
TCEMS CMD2 EMS Command 2 -Don't need, never heard it used in 4 years....
TCEMS CMD3 EMS Command 3 -Don't need, never heard it used in 4 years....
TCEMS CMD4 EMS Command 4 -Don't need, never heard it used in 4 years....
TCEMS EVENT1 EMS Event 1 -You can add, but not much going on here, for big events , EMS uses a interop channel to talk with all the other agencies.
TCEMS EVENT2 EMS Event 2 -Same as above
TCEMS EVENT3 EMS Event 3- Same as above
TCEMS EVENT4 EMS Event 4- Same as above
TCEMS EMERG EMS Emergency Emergency ID Activation
These channels below are used for major EMS calls, pin-in's, Hazmat, Structure fire support, large wrecks,etc. About 90% percent of the time these channels below are patched with an AFD blue channel. Normally, EMS TAC 1 will be patched to AFD Blue-1 and so forth for better scene managment.
TCEMS MCOM 1 EMS Medcom Tactical 1 EMS-Tac
TCEMS MCOM 2 EMS Medcom Tactical 2 EMS-Tac
TCEMS MCOM 3 EMS Medcom Tactical 3 EMS-Tac
TCEMS MCOM 4 EMS Medcom Tactical 4 EMS-Tac
TCEMS MCOM 5 EMS Medcom Tactical 5 EMS-Tac
TCEMS MCOM 6 EMS Medcom Tactical 6 EMS-Tac
TCEMS MCOM 7 EMS Medcom Tactical 7 EMS-Tac
TCEMS MCOM 8 EMS Medcom Tactical 8 EMS-Tac
I would suggest adding some hospitals, but it would just keep the channel even busier and you would miss alot of the call traffic. That's my 2 cents on the EMS side of things in Travis county.
