Everything you need to know about SFP Transceiver
sibyl
Banned
If you wanna know fiber optic tech, if you got to know SFP transceiver directly, then here is where you'll find information that will help you understand everything you need to know about SFP Transceiver.
Now fiber optic transceivers are commercially available for almost all international and industrial standards, including Ethernet, Fast Ethernet, Gigabit Ethernet, 10Gbit Ethernet. What's take an important role in this situation is SFP fiber optic transceiver. So let's take an eye on it.
SFP is also called small form-factor pluggable which is a version of Mini GBIC. at first sight, you can find the size is only half of GBIC. It supports data rates up to 10 G. The SFP Transceiver are available with a variety of transmitter and receiver types. What's more, it is with LC interface. SFP is regarded as a hot pluggable module, this make it Effortless to alter and effortless for upkeep in comparison with conventional modules. It makes the Ethernet network easier to upgrade and sustain. End users can replace a Solitary SFP module Throughout the Procedure Rather of replace the complete board with various modules on it. What makes us surprise is the working distance, from 500 metres to 100 kilometres. Working wavelength of different SFP modules are typically 850nm, 1310nm and 1550nm.
Many types of SFP transceiver modules, from 155Mbps to 10+Gbps are available, such as this lists: 1.25Gbps SFP Module, 2.125Gbps/2.5Gbps SFP Module, 622Mbps SFP Module, 155Mbps SFP Module, 1.25Gbps/2.5Gbps BIDI SFP Module, 2.5Gbps/1.25Gbps BIDI SFP Module, 155Mbps/2.5Gbps BIDI SFP Module, 2.5Gbps/155Mbps BIDI SFP Module, 622Mbps/2.5Gbps BIDI SFP Module, 2.5Gbps/622Mbps BIDI SFP Module, CWDM SFP,DWDM SFP.
Tips: At last, This source are come from Ingellen fiber optic manufacturer. Go ahead to check out the details!
