I'm trying to program an EVX-5400 UHF-d band radio and it won't communicate with my laptop(s).
I'm using CE-142 Version 1.21 downloaded from Motorola.
The cables are aftermarket bought from reputable USA dealers.
Laptop running Windows XP using serial port;
When using the traditional 9 pin serial cable on COM 1, I get a "Port Open Error"
when I try to connect.
Laptop running Windows XP using USB port;
When using the USB cable connected to the laptop and set to COM 1, the radio
starts beeping and the backlight flashes and this is before I open the software.
Same thing with the software open and trying to connect.
Laptop running Windows 8.1;
No serial port on this laptop so I used a USB serial adapter set to COM 1. When I
connected the traditional 9 pin serial cable to the adapter and laptop the radio
To sum it up, when the USB cables connect to the radio (with or without software
running) the radio will beep/flash and not connect.
With the 9 pin serial cable I get the "Port Open Error."
Any thoughts on this would be appreciated.
