Ok so I quoted the 275 from every county within 100 miles of me, everything i could put I would. So I apologize I am not as experienced as I said. The reason I cannot pick up these frequencies is because they are P25, DMR, NXDN? Is that the same as digital and trunked frequencies? What kind of scanner would I have to purchase to get these? I appreciate you taking the time out for me.
Thanks hiegtx
P25, DMR, and NXDN are all digital transmissions. They can be used either as 'conventional' channels, or as part of a trunked system.
For your county, Baxter, the database shows that Baxter County is using the statewide AWIN trunked system, but they also have some conventional (not trunked) channels, most of them are DMR.
Mountain Home has a few conventional channels, but it appears that they mostly use their NXDN trunked system.
For Marion County, the S.O. uses conventional DMR for Dispatch, but county fire indicates using conventional P25, with EMS using NXDN.
For an explanation of how a trunked system works, see this Wiki article:
Trunking Basics - The RadioReference Wiki
Your 125a can monitor channels that are not digital. Those are labeled as FM or FMN in the node column.
