Experiments with GMRS
adric22
Ft.Worth, TX
I got into radios a few months ago. I was trying to put together "emergency bags" for our two cars and I wanted some kind of backup communications device.
Originally I purchased some GMRS bubble-pack radios that claimed 20 miles. I was sorely disappointing when I found out I could only get about half a mile.
So I went back and spent even more money and bought some "36-mile" GMRS radios by motorola that also claim to support repeaters. Again, I was disappointed because the range was no better and I was not able to hit any of the repeaters in the area unless I drove within a mile or so of the tower.
So I decided to go back and buy some Midland hand-held CB radios. Again, sorely disappointing. The range was actually worse than the bubble-pack radios. So I bought telescoping antennas off of eBay that claimed to double the range of the handheld CBs... but there was no difference.
So the next thing I did was bought two Feidaxin FD-450a UHF radios off of eBay for about $100 for the pair. I programmed them with the 16 GMRS stations and I've been quite amazed. So far I've gotten 2.5 miles. I haven't tried going further yet, so I may be able to get even more than that. But that is 5 times further than I've been able to get with any other type of radio.
So I applied for and paid for my GMRS license today since it looks like I'll be using these as GMRS radios. I'm also studying to get a HAM license so I can use the other frequencies on my radio. However, between me and the family it will have to be GMRS because I do not believe my wife or daughter would ever be able to pass the HAM test. There is way too much technical stuff to know. Fortunately GMRS does not require a test.
So the lesson learned is that if you are serious about GMRS and want decent range, the FD-450a radios are cheaper than some of the bubble pack radios but have tremendously more range.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Realistically, with any of the bubble pack or other handheld GMRS radios, 2+ miles is the best you can get. The advertising on the packages is a lot misleading (there are other threads here already about this) unless you are communicating handheld to mobile or handheld to repeater or mobile to repeater.
A half mile on the FRS side with 0.5 watt is pretty reasonable. The 2 watt bubble pack GMRS radios should do at least double that or further depending on terrain.
If you really want to do it right, get some 5 watt portables certified for Part 95. They should be good for several miles reliably or further on the GMRS channels.
Feidaxin FD-450a UHF radios not FCC part 95 certified for GMRS or anything else either I believe.
hhrj
SC Low Country
I was going to bring this up earlier this morning but decided to see how long before someone else did.
When he gets one in hand and enters the FCC ID # in the database then he will know.
The FCC really raped people on this one.
Read my thread " Is a Motorola HT1000 certified for GMRS?"
Good Luck
