mainetrunk
After reading Marks scanner page, I went inside the globe--<func+globe> and made a few changes.. Here is before and after
...........BEFORE -------------------AFTER
max tunes 20 20
SQ WAIT 1 10 8
SQ WAIT 2 15 5
RF SQ FADE 10 10
DG INT PRIME 60 60
NOISE THRESH 20 120
WX CHECK INT 60 60
WX 1050HZ TH 20 20
WX ALARM TIME 90 90
STALKSCANSQ2 5 5
STALKSRCHSQ2 5 5
STALKSRCHSQ1 10 10
STALKAMDELAY 150 150
STALKFMDELAY 50 110
SPCLSTALKLMT 5 5
FLEX STEP OFF OFF
ADC CAL
RSSI BAR 1 370 470
RSSI BAR 2 450 540
RSSI BAR 3 520 610
RSSI BAR 4 610 680
RSSI BAR 5 680 750
ADC CAL OFF DSP
RSSI SIG CAL
RSSI BAR 1 370 470
RSSI BAR 2 450 540
RSSI BAR 3 520 610
RSSI BAR 4 610 680
RSSI BAR 5 680 750
BAT ICON CAL
NIMH OFF --511 DONT KNOW WAT HAPPENED--BAT CAL DISAPPEARED
ZEROMATIC VALS
5K IN LO 252 170
5K IN HI 252 480
5K OUT LO 210 150
5K OUT HI 594 530
IN LO 210 170
IN HI 594 480
ZM DELAY 5 5
ACSQ SRCINT 500 100
ASCQ POLINT 100 100
HD5 FADE 2000 2000
HD2 QUALIFY 75 75
RSSI BAR
HD2 HOLDOFF 500 500
96 CC HD2 TO 30 30
96 VC TO 100 100
96VC XF TO 30 30
HD2 QUAL DG 100 100
SUBBAND DELAY 150 150
M36 ET PATT 2B2B 2B2B
ENDTONEMOT 250 80
ENDTONE EDACS 10 10
EDACS UNMUTE 18 18
EDACS ET HO 35 35
TRUNKING CH# OFF OFF
SHOW RAFIO ID NO YES--JUST CHANGED IT
RADIOID ALERT NO YES
BAND PLAN USA USA
CCDUMP: NO NO
DSP DUMP NO NO
WOW,THATS FUN!!! Ok, so after I made these changes I noticed that when you TUNE-IN, the P.L, NAC are different---------example
159.405-nac,117 Before tune
now-159.405 /xf hd 5
155.010-192.8
now-------hd5 . once you store freq, the pl, or nac will will be waiting for a signal.. I noticed you can change the format of a trunking system. Before--432, after 400-3.
Ther are obvious changes. ther sensitivity went arah.. nothing like tinkerring. Good leuck. Ron
max tunes 20 20
SQ WAIT 1 10 8
SQ WAIT 2 15 5
RF SQ FADE 10 10
DG INT PRIME 60 60
NOISE THRESH 20 120
WX CHECK INT 60 60
WX 1050HZ TH 20 20
WX ALARM TIME 90 90
STALKSCANSQ2 5 5
STALKSRCHSQ2 5 5
STALKSRCHSQ1 10 10
STALKFMDELAY 50 110
SPCLSTALKLMT 5 5
FLEX STEP OFF OFF
ADC CAL
RSSI BAR 1 370 470
RSSI BAR 2 450 540
RSSI BAR 3 520 610
RSSI BAR 4 610 680
RSSI BAR 5 680 750
ADC CAL OFF DSP
RSSI SIG CAL
RSSI BAR 1 370 470
RSSI BAR 2 450 540
RSSI BAR 3 520 610
RSSI BAR 4 610 680
RSSI BAR 5 680 750
BAT ICON CAL
ZEROMATIC VALS
5K IN LO 252 170
5K IN HI 252 480
5K OUT LO 210 150
5K OUT HI 594 530
IN LO 210 170
IN HI 594 480
ZM DELAY 5 5
ACSQ SRCINT 500 100
ASCQ POLINT 100 100
HD5 FADE 2000 2000
HD2 QUALIFY 75 75
RSSI BAR
HD2 HOLDOFF 500 500
96 CC HD2 TO 30 30
96 VC TO 100 100
96VC XF TO 30 30
HD2 QUAL DG 100 100
ENDTONEMOT 250 80
ENDTONE EDACS 10 10
EDACS UNMUTE 18 18
EDACS ET HO 35 35
BAND PLAN USA USA
CCDUMP: NO NO
DSP DUMP NO NO
155.010-192.8
