That was a big brain fart on my aide for sure. I popped it into Google and it said 10 degrees. Clearly I am mistaken. But what is its cost? Tessco and Talley doesn't list them. My cost on the Telewave ANT125F2 is $605. List is $864. I think as we close this thread out we should stick to what is reasonably available to the average listener.
I think my overall point still holds true. While we try to hear everything from one location they have 30 or so remote locations for the Los Angeles region. I am roughly 100 miles by air from LAX and they only come in so-so using a discone. If I take an older model TV antenna (not digital) I can actually hear LAX better. Most bands don't resonate on the "Scanner Beam" sold by Grove.
The collinear is very easy to make using hard line and limiting it to a gain of 3dB. I've seen some rip the dialectric and center conductor out of coax and slide it into brass cylinders, but why? LOL. Hard line is just that -- hard. Others have cut coax into lengths and soldered away. Why? Use hard line.
But the easiest to make would be a 1/2 coaxial sleeve antenna. I've made several and it is a 1 hour project if you have the parts on hand.
6 Meter Repeater Antenna 1/2 Wave Coaxial Vertical Antenna Design Just scale it down for the air band. The assembly shown is my CHP antenna and it kicks butt even though they have almost all switched to repeaters.
You're after gain and that always narrows the signal aperture. For distant communications your antenna would rock. From up here it may really rock. But we have to remember that the average person in Los Angeles lives at an elevation that yields about 40 miles to the horizon. Not to mention that the FCC grants licenses generally on a 40 mile coverage and less at 800MHz.
I'd love to compare actual reception using the DPV-35 -- I got it right that time LOL. My examples are just good for local coverage. But we're talking about airborne communications. My examples tend to receive skywaves better than an antenna with 9dB gain side-mounted to a tower. Refer to the image above with the boat. That is my configuration on my repeater antennas and I know from 1st hand experience the effect of a 16 degree beamwidth. A HT down in Redlands is not as effective into my repeater as the same HT in Temecula (yes, our repeater has great receive!)
A Uniden BC785 scanner has a sensitivity of 1.5uV or worse as measured on my HP8924c. Even the Bendix KX-99 is just under 1uV. The two main differences are that the scanner does not use true AM demodulation (and the KX-99 does), and too much gain introduces birdies and images from the FM broadcast band. On a discone with 20 feet of RG6Quad I can hear it just trying to come in. I wonder if the poor sensitivity is linked to this issue?
Enough said. We each have a preference and those that want to build your antenna for the air band sure can have at it. But as I've said your antenna will truly rock where it is intended to play -- 138MHz and up for ground communications. At the end of the day it is up to the listener and what they can build.
