External accessory?
se
Minto, New Brunswick Canada
Hi All.
Is there an external hardware accessory that can be bought to fix the real time clock in the 536hp instead of sending it away?
Sheldon.
buddrousa
Sheldon as far as I know the answer is no. It is not an easy skill to remove components and replace them on new printed circuit boards. Do without the scanner a week or two and get it fixed the correct way.
ofd8001
Louisville, KY
As I understand it, there are two different issues covered by the RTC repair campaign. One is as mentioned, the RTC and the other is a fading display.
You could get past the RTC issue by always leaving the scanner powered up. With the fading display you could use a Virtual Control program such as ARC536 Pro.
FWIW, I bit the bullet and sent both mine back to Uniden. It was about a 3 week turnaround with 2 of those weeks being transit time. A guy could make an argument either way on whether this is a good time or bad to ship via UPS given Christmas present shipping going on.
se
I wont leave my 536hp running 24/7 because that would significantly increase my monthly electricity rates. and Ive been usibng ARC software ever since I bought my 536hp.
Sheldon.
phask
zanesville
Do you unplug the walwart as well? It's probably nearly the same on or off.
Have you checked it? I doubt if it's a watt or 2.
Sheldon.
se
Hi.
I have the AC adapter plugged into where it connects to the scanner and then the other end with the 2 prongs plugged into a APC BACKups multioutlet power supply.
Sheldon.
garys
Central Texas
Wow! I knew Canadians were, uh, frugal, but this is a bit extreme. Do you unplug your TVs, DVR, computers, and other things at night? All of those use more electricity than the scanner.
