Hi all, I am running my radarbox and a radar rama external antenna, I have popped 2 boxes now due to static to to box, can anyone please help with how to ground or best way to stop static discharging tothe box, I looked at DC blocks but I dont think that will help.
Im not too good with grounding etc so keep it simple.
Right now I have the antenna on top of a PVC tube that connects to the mast that holds the discone so there is no metal between the antenna and mast..will it help if I run alloy or metal pipe from the antenna to the mast then earth the mast to a ground rod or do i need to earth the coax too (or will earthing the mast sort that issue)
thanks everyone![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks everyone
