External Antenna?
E-542
Lancaster, PA
How, would I go about connecting an External to a Regency ACT-R10? I've got no clue how. And on the topic of the ACT-R10, where can I get a 12V Cord for it? Thanks!
fineshot1
NJ USA (Republic of NJ)
This is an old model crystal scanner and has not been made in many years. Its listed as having a Motorola plug in the back for an antenna connection so you will need an adapter from that plug to what ever connector type you will be using on your external antenna. It would probably be best to use an adapter cord rather than a regular adapter because the cord type would be more flexible. As for a 12V power cord you may have to make your own unless you can find one used some where but that is doubtful.
