DSDPlus Extra traffic file (error?)
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
anyone know what's the cause of this error?
monitoring a CAP+ system (still figuring it out....)
TIA
doug
slicerwizard
Toronto, Ontario
Are you using DSD+ 1.101? IIRC, it sometimes fails to delete all of the .traffic files it creates and then complains about seeing them. Check your DSD+ folder for any .traffic files and delete them.
batdude
Moderator
DSD 2.246 FL if that helps... i noticed that there are ".traffic" files in the DSD+ directory when running, but they get deleted when I exit the program.
here is the background.... pls bear with me because CAP+ DMR trunking is still new to me.
this is the system I am attempting to "track" -
here is the .frequencies file as I have it configured. I suspect that this is the cause of my problems, i am just unsure how to fix it.
Cap+, 0, 6, 1, 464.7375, 0.0, 0
Cap+, 0, 6, 2, 464.7375, 0.0, 0
Cap+, 0, 6, 3, 462.125, 0.0, 0
Cap+, 0, 6, 4, 462.125, 0.0, 0
Cap+, 0, 6, 5, 464.3375, 0.0, 0
Cap+, 0, 6, 6, 464.3375, 0.0, 0
when I look at 464.7375, DSD+ reports this as a CAP+ repeater, site 6. the other 2 freqs above are most certainly associated with this system, but I am not sure about the LCN/LSN pairing (in other words, not only is my frequencies file above a SWAG - I don't have a lot of faith that the site info on RR is correct, either.
so - two part question I guess --- is my freq file in the correct format.... and if not, what is the best way to figure it out?
thanks for the help,
doug
