In order to "auto-convert" your current RCS talkgroups into your new NextGen systems in Whistler EZ-Scan, first select Trunking Options Talkgroup ID Mode, and change it from decimal to HEX. Next, create your new Project 25 Nextgen system with sites. Then, go to the talkgroup list of your current RCS system, and right click and select Export All Talkgroup Objects to CSV File. Next, open the saved file in Windows Notepad, and select EDIT/SELECT ALL. Go back into EZ-Scan, to your NextGen talkgroup list, which is probably blank, and select Import From Clipboard.
Congratulations, you now have a properly formatted talkgroup list conforming to Project 25 with correctly auto converted talkgroup ID's. You may now switch back to normal or decimal view mode.
THIS ALSO WORKS FOR SD CITY 800 TO 700 CONVERSION.
Paul
Paul
