designeq
Just got the TRX-1 and am trying to set up scanlists. I have 5 I'm trying to set up via the Preferred Import type. I set the first one up without problems. Then it got strange. I would create another scanlist by importing from the DB. It would seem to go fine, but when I set up a third one, all the data from the previous scanlist would be gone!
There are several other questions I have about importing from the DB but I'll get to those once I solve this problem.
Now I'm at the point where I have two scanlists populated but when I try to create a third by importing from the DB, it always contains nothing.
Under what circumstances would EZ Scan take you through the Library Import process, show you a list of talkgroups which are selected, and then, upon clicking Import Selected Channels and selecting a scanlist to import into, ends up with that scan list being empty?
And here is something even more bizarre: this problem occurs when running EZ Scan under Windows 7 via bootcamp on my Mac. I also have it running under CrossOver on another Mac (CrossOver doesn't require Windows). I can't use CrossOver to program the scanner because, so far, it can't actually communicate with the scanner (driver issues?) but it does allow me to use the database without problems. With EZ Scan under CrossOver, this case of vanishing data in the scanlists does not occur and I can set up multiple scanlists as I would expect things to work. As far as I can tell, I have EZ Scan set up the same on both computers and I am following the same procedures on each.
Too weird! But right now I'm dead in the water since I can no longer create the scanlists that I want to send to the scanner.
Clearly there is something about EZ Scan I am missing. Any ideas pointing in the direction of a solution would be appreciated.
Update: Before I sent this I decided to try to actually program the scanner with the two scanlists that I could create. This worked as expected, but when I went back to try to create another scanlist, the same thing happened: the data was imported but the scanlist was empty (???!)
