EZScan delay Time slider sensativity? & Channel Edit
Machria
Long Island, NY
Anyone else notice the sensitivity of the "Delay Time" slider in EZscan is a bit clumsy?
I can not set a channels delay time to 4.0, I can set it to 3.9 and 4.1, but it is not possible to stop at 4.0. I'm sure it has something to do with display resolution or something.
Do any of you see this problem?
Another thing I just found is, you can not edit a channel from the Scanlist tab. You have to click on the Conventional Frequencies tab and then scroll to find the channel you want to edit, and then clicking on each columns item to edit it (in cell editing). They should make a consistent "EDIT CHANNEL" button where ever a channel or channels are being displayed instead of allowing the "in cell" type editing currently being used in only certain area's. It would make it easier for them from a programing standpoint as well because there would only be one [EDIT_CHANNEL] object in the code.
