norm1153
- Joined
- Mar 17, 2005
- Messages
- 9
EZScan image from a Print Screen. Note that many column text headings are jumbled, overwritten, or just indecipherable. For example, the center column headings for Scanlist Control, and several problems over on the left side, just below Backlight Settings.
How does the program write changes to the TRX-1? Does it happen immediately after you make any change to a button, or is there a "write" or "download" button to write it to the TRX-1? For example, I changed the 5th line of the Welcome text, but the change is not reflected in the TRX-1. And I unplugged the TRX-1 USB cable, recycle the power, to see if the changes "took" but they do not.
Thanks for any advice or suggestions!
Norm
Norm
