Ezscan: move from Conventional tab to Scanlist
Seymourmtn
Seymour, Tn
Greetings all
I have imported items into the Convential Frequenies tab. Of Ezscan,
Now, how do I move those channels to a Scanlist?
Thsnks for any help
Doug
RDGDigital
MD - Eastern Shore
From the Conventional Frequencies tab, click on the object you want to "move". Then click on that object's cell that's in the Scanlists column. A pop-up will show where you can check/uncheck which Scanlists you want that object assigned to.
Hope this helps.
Seymourmtn
Seymour, Tn
EZSCAN import
Thanks for the quick response
All is well, from your instructions. Except, I had to make the requested Scanlist..the Default. No problems.
Thanks again
Doug
