ezstream - default: Stream has no configuration
va3kxp
Toronto, Ontario
Hello,
I am just about at my wits end. I am attempting to setup a feed from my Allstar node to Broadcastify. I followed the HowTo provided at https://www.hamvoip.org/howto broadcast your allstar node.pdf.
I keep getting the following message;
ezstream[14324]: default: stream has no configuration
I have tried this on three different installations of Allstar with the same results.
The following is my ezstream.xml file;
<ezstream>
<url>http://audio1.broadcastify.com:80/ngs5rmf1pjx8</url>
<sourcepassword>password/sourcepassword>
<format>MP3</format>
<filename>stdin</filename>
<svrinfoname>VA3KKF 443.9750 MHz Repeater</svrinfoname>
<svrinfourl>http://www.broadcastify.com</svrinfourl>
<svrinfogenre>Amateur Radio</svrinfogenre>
<svrinfodescription>VA3KKF 443.9750 MHz Repeater</svrinfodescription>
<svrinfobitrate>16</svrinfobitrate>
<svrinfochannels>1</svrinfochannels>
<svrinfosamplerate>22050</svrinfosamplerate>
<svrinfopublic>0</svrinfopublic>
</ezstream>
Does anyone have any clue as to why this is happening?
Thank you,
Stephen va3kxp
va3kxp
Toronto, Ontario
This turned out to be an issue with the Hamvoip implementation/installation of ezstream. The folks at Hamvoip released an update is everything started working.
