F-11 programming/no audio
mist668
I programmed my F-11 to the frequencies I desired, but I can not get any audio or any indication that the repeater system I am using, is getting any signal from the handheld. I have programmed simplex channels on known busy frequencies to no avail. I even got desperate to see what was wrong and programmed the radio for NOAA channels, in which it will no receive audio from them as well. My question is, what exactly am I programming in CS-F11 incorrectly to make the radio not work?
rescuecomm
Travelers Rest, SC
It would help if you would list one full horizontal line of data from your CS-11 file. Some things to mind would be setting the two tone decode active on all channels or wrong CTCSS/DTS. The green light on top of the radio should be on if a signal is being received on the Wx frequencies.
Bob
mist668
RapidShare Webhosting + Webspace
I just tested with my ft-8900r that works. The f-11 is transmitting but when I try to transmit back on the yaesu I get no audio. I figured that it was probably a tone mis match to I programmed both the F-11 and the 8900r for 155.000 no tones. F-11 would transmit but not receive.
RADIOGUY2002
Chicago Burbs
aTTACH IMAGE OF SCREEN SHOT
Attach image of screen shot, you could have miss a simple step. Find prtsc and duplicated the images in the art format, etc and then post images.
RADIOGUY2002
Chicago Burbs
check these settings out
mist668
Attached is the screenshot of the programming info.
bezking
On the Road
Assign one of the buttons to "MONI." Hold it down and see if you hear static.
Nothing looks funny about your programming based on that screenshot.
mist668
I just bought it a week ago from a known good online retailer. He has me rma it back.
ElroyJetson
RF connector failures are not uncommon on those radios. Quite often it's just a broken solder joing where the RF connector pin meets the circuit board. Easily fixed by retightening the screws that hold the RF connector into the frame (Loctite on those screws is HIGHLY recommended) and resoldering the connection on the circuit board.
I deal with those radios very frequently.
Elroy
RADIOGUY2002
Chicago Burbs
RF issue
Elroy, he sent back to the shop. But, I to have seen the rf issue happen before as well. Damm RF... ugh the nightmare of my life.
