F-6061 and UT119 Digital Board
Disp46
I have added a UT-119 Digital board to a 6061 Mobile but it is not decoding the digital messages being received, just the digital sound in analog mode. In fact, in the Informatoin section of the software, the radio doesn't even recognize the UT-119 board as being installed. The radio has firmware version 3.0. I am wondering if the firmware is at a level beyond the UT-119 level and would require the newer UT-126 board instead. If that is the case, can the firmware be downgraded to match the UT-119?
I hope someone can help me out with ideas. Thanks.
Disp46
The 6061 probably needs the UT-126 modele.
I have an F5061 and it works, and recognizes the 126
I am thinking that the firmware version in this particular radio (3.0) is compatible with the UT-126 and not the UT-119. I have another F6061 with firmware version 1.0 and it works fine with the UT-119. I am wondering if it is possible to regress firmware and go back to an older version of firmware that is compatible with the UT-119.
gmrsoutlet
Oswego, IL
The firmware on the UT119 needs to be upgraded.
Once upgraded the UT119 "becomes" a UT126.
Send me a PM and I will get you setup with what you need.
