Fatman2
Hi everyone,
I am the newly appointed communications manager for our Fire Department. The department currently uses the ICOM F33GS VHF Handheld portables...The department purchased programming software and cable for me to be able to update/reprogram the units. I just received everything and installed it on my laptop Following the supplied directions to setup the software all went well. I am having problems reading from the radio to see what is currently in there. I keep getting a COM port error...I have tried changing com ports and have found a new error on the COM port 4 setting..."no answer from the transceiver". This is the only software I am experiencing problems with. The Vertex Software for the mobiles and the Motorola software for the pagers all work fine. Can anyone shed some light on this?
Thank you,
Thank you,
