As I asked above-
What are you slow and fast scan settings?
From the help sections of the software-
Slow Scan (Sec)
Enter the time period for scanning of each channel with CTCSS/DTCS programming.
The recommended time is set by default and scan may not stop when setting a value shorter than the default
Fast Scan (Sec)
Enter the time period for scanning of each channel without CTCSS/DTCS programming.
The recommended time is set by default and scan may not stop when setting a value shorter than the default.
FNOTE:
This time period is also used for the Vote Scan that can be selected in the Zone Operation screen.
A total of 17 scanning lists are available for a wide variety and flexible scanning operation. In this screen, program scanning condition for each list.
The Scan list "Zone" set channel is scanned when it is being included in the same zone with the scan start channel.
l Display Text
Enter up to a 12 or 24-character* text to indicate message, etc. and/or indicating the scan list during scanning.
* Depending on the Display Lines setting in Key & Display Assign.
-> Details of Text setting.
l Scan Type
Set the scanning type to each scan list. Scan OFF, Normal Scan and Priority Scan are available.
The watch time period, the power ON scan function etc. is programmed in Scan Setting screen.
Scan OFF:
Scanning operation is turned OFF.
Normal Scan:
Normal scan. Scans all selected channels. The scan proceeds in sequence.
Priority Scan:
Priority scan. "Primary CH" and "Secondary CH" are used as the priority channel.
The selected channels are scanned in sequence while monitoring "Primary CH" and "Secondary CH."
When scan is paused on "Primary CH," other channels are not monitored.
When "Secondary CH" is not set:
When a signal is detected on a channel other than "Primary CH," scan pauses until the signal disappears and "Primary CH" is continuously monitored.
Scan moves and pauses on "Primary CH," if the signal is detected on.
When "Secondary CH" is set:
- When a signal is detected on a channel other than "Primary CH" or "Secondary CH," scan pauses until the signal disappears and "Primary CH" and "Secondary CH" are continuously monitored alternately.
Scan moves and pauses on "Primary CH" or "Secondary CH" if the signal is detected on.
- When a signal is detected on "Secondary CH," scan pauses until the signal disappears and "Primary CH" is continuously monitored.
Scan moves and pauses on "Primary CH" if the signal is detected on.
* "Prio A" means "Primary CH," and "Prio B" means "Secondary CH."
FNOTE:
The scanning channels are selected in Scan List in the Zone screen.
The compatibility of the previous and current scan mode:
* "R.Sel CH" is available only for Portable type transceivers. Select "Start CH" instead of "R. Sel CH" for Mobile type transceivers.
FNOTE:
To set Vote scan mode (Mode1), select "Voting" in Zone Type in the Zone Operation screen.
l Primary CH
Select the desired channel as a primary channel. The selected channel is monitored during priority scan.
Prio-A CH : The priority A channel is used as the primary channel.
Prio-B CH : The priority B channel is used as the primary channel.
Start CH : The scan start channel is used as the primary channel.
R.Sel CH : The selected channel by the rotary selector is used as the primary channel.
CH Number Select : The selected channel is used as the primary channel.
FNOTE:
R.Sel CH can be available only for Portable type transceivers and when "MR-CH" is selected in Rotary Selector in the Key & Display screen.
l Secondary CH
Select the desired channel as a secondary channel. The selected channel is monitored during priority scan.
The secondary channel is lower priority than primary channel.
Disable : The secondary channel is not used.
Prio-A CH : The priority A channel is used as the secondary channel.
Prio-B CH : The priority B channel is used as the secondary channel.
Start CH : The scan start channel is used as the secondary channel.
R.Sel CH : The selected channel by the rotary selector is used as the secondary channel.
CH Number Select : The selected channel is used as the secondary channel.
FNOTE:
l TX CH
Select the desired channel as a transmission channel.
Last CH : Transmission is performed in the channel scan stopped last. If it is no last channel, the scan start channel is selected for transmission.
Prio-A CH : Transmission is performed in the priority A channel.
Prio-B CH : Transmission is performed in the priority B channel.
Start CH : Transmission is performed in the scan start channel.
R.Sel CH : Transmission is performed in the selected channel by the rotary selector.
CH Number Select : Transmission is performed in the selected channel.
FNOTE:
l Talk Back
Turn the talk back function for transmission ON or OFF.
The function allows you to transmit a signal at the channel that the scan stopped last, when the transmission is performed during the scan stopping or the talk back timer* (after the resume timer has passed).
When "OFF" is selected, the channel selected in TX CH is always used for transmission.
* Talk back timer is set in Talk Back (Sec) in Scan Setting screen.
l TX Action
Select the scan action when transmission is performed during scanning.
Cancel Scan : Scan is cancelled and transmission is performed in the channel that is selected in TX CH.
If Talk Back is turned ON and transmission is performed during the scan stopping or the talk back timer, the signal is transmitted and the scan is canceled at the channel that the scan stopped last.
Pause Scan : Scan is paused until the signal disappears and then resumes after the resume timer* has passed.
* Resume timer is set in Resume (Sec) in Scan Setting screen.
l Cancel CH
Select the desired channel type that is selected when scan is cancelled (except for transmission.)
Start CH : The scan start channel is selected automatically.
Start CH/Talk Back : The scan start channel is selected automatically when scan is cancelled during scanning.
The channel scan stopped last is selected automatically when scan is cancelled during the scan stopping or the talk back timer (after the resume timer has passed).
R.Sel CH : The channel that is selected by the rotary selector is selected automatically.
R.Sel CH/Talk Back : The channel that is selected by the rotary selector is selected automatically when scan is cancelled during scanning.
TX CH : The channel that is selected in TX CH is selected automatically.
TX CH/Talk Back : The channel that is selected in TX CH is selected automatically when scan is cancelled during scanning.
FNOTE:
R.Sel CH and R.Sel CH/Talk Back can be available only for Portable type transceivers and when "MR-CH" is selected in Rotary Selector in the Key & Display screen.
l Text
Select the text indication capability from OFF, Text or Start CH during scan.
While the scan is pausing on a channel by receiving/transmitting a signal, the channel's text is indicated regardless of the setting.
OFF : The text indication is turned OFF.
Text : The text indication is turned ON. The channel's text that is programmed in Display Text as above is indicated during scan.
Start CH : The text indication is turned ON. The scan start channel's text is indicated during scan.
l PWR Save (For Portable type transceivers)
Turn the power save function ON and OFF during scan.
Total scanning speed is decreased when the function is activated.
