F70 Transmit Problem
Matted33
For what ever reason my F70 is having a problem transmitting on duplex channels but on channels that are in simplex, it works just fine. Any idea what it could be that's causing this?
cabletech
Puget Sound
What is the exact problems? Are you trying to go thru a repeater or radio to radio? Are you sure you have the correct frequencys and pl/dpl?
Matted33
When I go to transmit on channel 1 which goes through a repeater, nothing goes out. Channel 2 which is a point to point channel using the repeater"s out put works just fine. I have 3 radios that are programmed the exact same way, frequencies and PL tones and they don't have any issues.
cabletech
Puget Sound
So take a scanner or reprogram one of the radios to the channel 1 in tx frequency w/pl and see if you can hear the other radio.
Also recheck the program and make sure that you have not checked the tx inb option as that turns off transmit on that channel.
If, by using a scanner or doing the reprogram on another radio, you are able to hear the test radio tx, then you need to verfy that you have the correct pl for the repeater.
Matted33
Thanks for the help, I now see that there is a transmitting problem. when the radio is more than 2 or 3 feet away from another radio, it won't reach. I guess it has to get sent in to ICOM.
cabletech
Puget Sound
sounds like a broken antenna connecter. Send it to Icom in Bellvue Wa $80 + shipping and you will have it working.
Matted33
I got the transmitting issue resolved, but I was wondering what version of programming software or firmware do I need so I have MDC signalling on my F70. My programming software is version 2.0 radio revision 3.0.
