SDRTrunk Fade Issue
scottct1
Newington, Connecticut
Not sure what's up, but I have been using SDRTrunk for awhile and it's been working fine.
Today however I use it and it will not tune to any of my talk groups. When a Talkgroup pops up the status goes from IDLE to FADE immediately.
Looking at the signal power I am getting around 23.4 which should be fine.
I uninstalled and reinstalled it... I even installed it on a new laptop and am getting the same thing... and it's orhappening no matter which trunk group I am using.
The Pink Colored ENCRYPTED seem to have no problem, but the unencrypted on always immediately say fade and I get no audio
For those wondering this is the Connecticut P25 CLMRN system.
Any ideas?
hazrat8990
Wyoming
How's the noise floor? I noticed that I was having a similar issue with one of the control channels I monitor. I messed around with antenna position, gain settings, installed ferrites on USB cable and coax. Nothing seemed to work and I was starting to get frustrated. All of this headache turned out to be the LED porch light!
ChrisABQ
Murder-Querque, NM
I was having some issues with SDRTrunk also, mostly crashes. Try unplugging the SDR's and hub if you have one, restart and plug everything back in, it's like doing a SDR cache reset. Let me know if it works.
scottct1
I have restarted, reiserted, tried on a different laptop, Used different SDR devices and still not hearing anything... everything just says FADE when it tries to play... all was working great before and I didnt change anything.
I even took my machines to work today to see if it was some kind of interference issue. And having the same issues here.
On this machine I am on now all the tuner settings are default and I have not adjusted them at all.
Here is a screen shot.. from what I see it looks good and the signals look good to me, so maybe I am missing something.
ChrisABQ
Murder-Querque, NM
Another thing you can try is going backwards through the older versions of SDRT and see if/when things may start to work again.
hazrat8990
Wyoming
I was just going to suggest the same thing. I tried one of the newer releases of the nightly build and had issues with it freezing and a few other things. I ended up going back to the previous nightly build. This version seems to be the most stable so far.
dave3825
Suffolk County NY
Mine looks like this.
Yours looks like this
Post a screenshot of your tuners tab showing PPM and gain settings. Like this,
freema22
Michigan
I am experiencing EXACTLY the same thing. It worked great for MONTHS and all of a sudden, it is deaf as a post. I can see lots of strong signals on the waterfall, and can hear them on my old Whistler 1065 that shares the antenna. SDRTrunk isn't hearing anything. I verified this on a separate computer with a different SDR, and experienced the same thing. I really believe it's a software issue.
maus92
The OP
Hmm, as @dave3825 illustrates, it looks like the sdr device has drifted off frequency. The ppm needs readjusting, and it's possible the sdr device is failing.
