failed- phase2_tdma option not enabled
N2WH
I've just installed OP25 and have it running on the NJCIS system. In the log, I'm getting the above error. I'm starting it with:
sudo ./rx.py --args 'rtl' -N 'LNA:47' -S 2400000 -f 774.781250e6 -o 25000 -T trunk.tsv -v -2 -U 2> stderr.2. Now the only time I don't rcv audio, is when a TDMA slot shows being received. when I receive a signal without that, audio is fine. Anyone ever run into this while using the -2 option?
-Bill
boatbod
Talbot Co, MD
-Bill
The error is in your command line options. Change the "-v" to a "-V" (or eliminate it) and then the -2 will be recognized. Right now you are setting log level (-v) to "-2"
N2WH
Well that was easy. Thanks for the quick reply!
-Bill
