Failure to receive the correct Preamble
bravehamid
HI
I'm using a USRP to receive a signal on the 900 MHz frequency band, but the signal received after demodulation has no preamble. Does anyone know what the cause is?
transmitter information:
Baud rate=10K
modulation = BFSK
deviation = 100K
channel spacing = 350K
boatbod
Talbot Co, MD
Preamble is going to depend on the protocol. What are you monitoring?
What application are you using to attempt the decode?
bravehamid
my module is XTP9B and I'm trying that receive data with USRP B210(with gnuradio).Sender of the module is ADF7023.In the datasheet ADF7023: Preamble=0x55
