Fairfax County Police Designators
KI4IHC
Here's a list of all the Fairfax County Police Dept. radio/CAD designators.
Straight from FCPD SOP #04-014
Patrol Bureau Commander—Division I
Radio: "Patrol Bureau 1"
CAD: "PB01"
Patrol Bureau Commander—Division II
Radio: "Patrol Bureau 2"
CAD: "PB02"
Patrol Bureau Commander—Division III
Radio: "Patrol Bureau 3"
CAD: "PB03"
Patrol Bureau Staff
Radio: "Patrol Bureau" + consecutive number beginning with 3
CAD: "PB" + consecutive number beginning with 03
Station Commanders
Radio: "Commander" + station number
CAD: "CM0" + station number
Assistant Station Commanders
Radio: "Commander" + station number multiplied by 10
CAD: "CM" + station number multiplied by 10
Additional assistant station commanders would be numbered consecutively.
The following radio and CAD designators are to be used by patrol personnel. Shift identifiers will be used at all times as part of the mobile unit designator. The shift identifiers are as follows, except where noted below:
A–Midnight and Early Midnight
B–Day Work
C–Evening
D–Early Day Work
E–Early Evening
A representative sample of the Mobile Unit Designators for patrol personnel (officers, field unit members, sergeants, second lieutenants, assistant station commanders, and station commanders) is provided in Appendix I to this SOP.
Patrol Second Lieutenants
Radio: "Car" + station number + shift identifier
CAD: "0" + station number + shift identifier
Additional second lieutenants working the same shift would replace the shift designator with "D" or "E."
Patrol Sergeants
Radio: "Car" + station number multiplied by 10 + shift identifier
CAD: "0" + station number multiplied by 10 + shift identifier
Additional sergeants working the same shift would be numbered consecutively.
Patrol Officers
Area Cars
Radio: "Scout" + patrol area + shift identifier
CAD: "Patrol Area" + shift identifier
Second unit in a patrol area: Substitute "5" for third digit in the patrol area.
Radio: "Scout" + first two digits of patrol area + "5" + shift identifier
CAD: First two digits of patrol area + "5" + shift identifier
Unit assigned to two or more areas simultaneously shall use the designator for the lowest numerical patrol area assigned. The Public Safety Communications Center shall be notified in all cases of multiple core area assignments. Core areas are determined by the first two digits in the three-digit designator.
Field Units
Radio: "Scout" + "9" + station number + a consecutive number beginning at 0 + shift identifier
CAD: "9" + station number + a consecutive number beginning at 0 + shift identifier
Patrol units manned by two sworn, fully trained officers. (This designator is not used to indicate an auxiliary or trainee is present.)
Radio: "Scout" + first two digits of patrol area + "9" + shift identifier
CAD: "Scout" + first two digits of patrol area + "9" + shift identifier
Patrol units operating the paddy wagon
Assigned a patrol area
Radio: "Scout" + first two digits of patrol area + "8" + shift identifier
CAD: First two digits of patrol area + "8" + shift identifier
Assigned to the field
Radio: "Scout" + "9" + station number + "8" + shift identifier
CAD: "9" + station number + "8" + shift identifier
NOTE: If a paddy wagon is assigned to a double unit, the wagon designator "8" will take precedence over the double unit designator.
Criminal Investigations Section
Supervisor
Radio: "CIS" + station number
CAD: "IS0" + station number
Detectives
Radio: "CIS" + station number + a consecutive number beginning with the number 1
CAD: "IS" + station number + a consecutive number beginning with 1
NOTE: To preclude the need to use three-digit designators, it is recommended that CIS call signs not be permanently assigned.
Crime Prevention
Radio: "CP" + station number
CAD: "CP0" + station number
Second Crime Prevention Officer
Radio: "CP" + station number multiplied by ten
CAD: "CP" + station number multiplied by ten
Additional units would be numbered consecutively thereafter.
Crime Analyst
Radio: "CA" + station number
CAD: "CA0" + station number
Communications Assistants/Desk Officers
Radio: "PCA" + station number
CAD: "PCA" + station number
Stake?Out Units
Radio: "X?ray" + station number multiplied by ten, then numbered consecutively
CAD: "X0" + station number multiplied by ten, then numbered consecutively
NOTE: "X?ray" 90 through 99 are reserved for use by CIB. "X?ray" 1?19 are to be used for stakeouts not specific to a single station.
Shopping Center Units
Radio: "Shopping Center" + station number + a consecutive number from 1 to 9 as needed
CAD: "SC" + station number + a consecutive number
Non?Patrol Assignments
Radio: "Victor" + station number + a consecutive number from 1 to 99 as needed
CAD: "V" + station number + a consecutive number from 01 to 99 as needed
Selective Enforcement Teams (SET)
Supervisor
Radio: "Set" + station number
CAD: "ST0" + station number
Officer's Radio
Radio: "Set" + station number + a consecutive number from 1 to 9 as needed
CAD: "ST" + station number + a consecutive number from 01 to 09 as needed
School Education Officers
Radio: SEO + station number + consecutive number 0 through 9
CAD: SE + station number + consecutive number 0 through 9
School Resource Officers
Radio: SRO + station number + consecutive number 0 through 9
CAD: SR + station number + consecutive number 0 through 9
Staff Duty Officer
Radio: "Duty Officer" + a consecutive number beginning with the number 1
CAD: "DO0" + a consecutive number beginning with the number 1
"Duty Officer 1," "Duty Officer 2," and "Duty Officer 3" will be used by the patrol bureau commanders; "4" will be used by majors, "5" will be used by captains, and "6" will be used by lieutenants while serving as duty officers on a temporary basis.
Youth Services
Radio: "Youth Services 1" through "Youth Services 99"
CAD: "YS" + consecutive number from 01 through 99 (e.g., "YS04")
Parking Enforcement Officers
Radio: "Parking Enforcement" + station number + a consecutive number from 1 to 8 as needed
CAD: "PE" + station number + consecutive number from 1 to 8 as needed
Animal Control
Commander
Radio: "Animal Control 1"
CAD: "AC01"
Chief Animal Control Officer
Radio: "Animal Control 2"
CAD: "AC02"
Supervisors
Radio: "Animal Control 01" through "Animal Control 11"
CAD: "AC01" through "AC11"
Animal Control Officers assigned to patrol
Radio: "Animal Control" + station number + a consecutive number from 1 to 9 as needed
CAD: "AC" + station number + a consecutive number
Animal Control Officers assigned to field or other special assignment
Radio: "Animal Control" + consecutive number from 90 to 99
CAD: "AC" + consecutive number from 90 to 99
OPERATIONS SUPPORT BUREAU PROCEDURES
Commander
Radio: "OSB1"
CAD: "OB01"
Special Operations Division
Commander
Radio: "OSB2"
CAD: "OB02"
K?9 Unit
Second Lieutenant
Radio: "K?9?1"
CAD: "K901"
Sergeant
Radio: "K-9-2"
CAD: "K902"
Officers
Radio: "K9" + consecutive number beginning at 3
CAD: "K9" + consecutive number beginning at 03
TAC Unit
Supervisor
Radio: "TAC1" through "TAC2"
CAD: "T001" through "T002"
Officers
Radio: "TAC" + consecutive number beginning at 3
CAD: "T0" + consecutive number beginning at 03
Hostage Rescue Vehicle
Radio: "HRV1"
CAD: "HRV1"
Explosive Ordnance Disposal Unit
Radio: "EOD1" through "EOD9"
CAD: "EOD1" through "EOD9"
Civil Disturbance Unit
CDU Commander
Radio: "CD1"
CAD: "CD01"
Squads
Radio: "CD" + squad + element
Example: First Squad will use the following designators:
"CD11" – First Squad, First Element
"CD12" – First Squad, Second Element
"CD13" – First Squad, Third Element
CAD: "CD" + squad + element
CDU Transport Bus
Radio: "CD50"
CAD: "CD50"
CDU Transport Van
Radio: "CD60"
CAD: "CD60"
CDU Equipment Van
Radio: "CD70"
CAD: "CD70"
Marine Patrol Units
Radio: "MP" + sequential numbers
Emergency Room Units
Radio: "ER" + sequential numbers
Probation and Parole
Radio: "PO" + sequential numbers
Traffic Division Commander
Radio: "OSB3"
CAD: "OB03"
Accident Reconstruction Unit
Radio: "ARU1" through "ARU9"
CAD: "ARU1" through "ARU9"
Motor Unit
Supervisors
Radio: "Motor 1" and "Motor 2"
CAD: "M001" and "M002"
Officers
Motor Unit assigned to an area. M + first number of area assignment + number.
Radio: "Motor 21 Baker" – First early unit assigned to stations 2 and 6
"Motor 22 Baker" – Second early unit assigned to stations 2 and 6
"Motor" 91 through 99 – Field units and selective enforcement
CAD: "M21B"
"M31E"
NOTE: Motor officers assigned to 0600-1630 shift will utilize the "Baker" designator. Motor officers assigned to the 0900-1930 shift will utilize the "Edward" designator.
Motor Carrier Safety Officers
Radio: "MCS1" through "MCS9"
CAD: "MCS1" through "MCS9"
Auxiliary Police Unit
Radio: "Auxiliary" + assigned EIN
CAD: Use the 4 digits of assigned EIN
All Other Traffic Division Units
Supervisors
Radio: "Traffic 2" through "Traffic 9"
CAD: "TD02" through "TD09"
Officers
Radio: "Traffic 10" through "Traffic 99"
CAD: "TD10" through "TD99"
Traffic Enforcement Unit
Supervisors
Radio: "Traffic Enforcement 1"
CAD: "TE01"
Area Officers
Radio: "Traffic Enforcement" + station number + consecutive number from 1 to 8 as needed
CAD: "TE" + station number + consecutive number from 1 to 8 as needed
Traffic Enforcement Units staffed by two TEOs
Radio: "Traffic Enforcement" + station number + "9"
CAD: "TE" + station number + "9"
Helicopter Division
Commander
Radio: "OSB4"
CAD: "OB04"
Helicopter Team
Radio: "Fairfax" + consecutive number beginning at 1
CAD: "FX0" + consecutive number beginning at 1
Officers
Radio: "OSB" + consecutive number beginning at 25
CAD: "OB" + consecutive number beginning at 25
NOTE: These designators may also be used for other officers or civilians assigned to OSB.
CRIMINAL INVESTIGATIONS BUREAU
Commanders
Radio: "CIB1" through "CIB9"
CAD: "I001" through "I009"
Supervisors
Radio: "CIB10" through "CIB99"
CAD: "I010" through "I099"
Other CIB Units
Radio: "CIB100" through "CIB999"
Each block of one hundred is assigned to the following squads:
Auto
100
Check and Fraud
200
Child Abuse, Juvenile, and Fugitive
300
Homicide
400
Robbery
500
Sex
600
Narcotics/Vice
700 and 800
Criminal Information Unit
900
Gang Investigations Unit
Radio: "Gang Unit" 1 through 20
CAD: "GU01" through "GU20"
Victim Services
Radio: "Victim Services" 1 through 9
SUPPORT STAFF PROCEDURES
Members of the support staff assigned to administrative, support, and staff duties are assigned designators as follows:
Crime Scene Section
Supervisor
Radio: "CS1"
CAD: "CS01"
Officers and Staff
Radio: "CS2" through "CS25"
CAD: "CS02" through "CS25"
Public Information Office
Public Information Director
Radio: "PIO1"
CAD: "PIO1"
Officers and Staff
Radio: "PIO2" through "PIO9"
CAD: "PIO2" through "PIO9"
Police Chaplains
Radio: "Chaplain" + station number
CAD: "CHP" + station number
Administrative Units
Administrative unit designators are for civilian and sworn personnel who are not addressed elsewhere in this SOP. Each bureau prefix shall be followed by consecutive numbers as assigned by the affected bureau commander. In all cases, 1 through 10 should be reserved for supervisors of units within these entities (e.g., "Admin 3" should be utilized by a supervisor in Administrative Support). The following examples should be used when assigning designators:
Radio: "Admin 15"
CAD: "AB15"
Radio: "IA 1"
CAD: "IA01"
Radio: "Community 4"
CAD: "CB04"
Radio: "Tech Services 3"
CAD: "TB03"
Radio: "Research 13"
CAD: "PR13"
Radio: "Warrant Service 11"
CAD: "WS11"
Radio: "Academy 10"
CAD: "AY10"
Radio: "Academy BUS"
CAD: "AYBS"
Honor Guard
Radio: "Honor Guard" + consecutive number from 01 through 09
CAD: "HG" + consecutive number from 01 through 99 (e.g., "HG02")
CHIEF OF POLICE AND DEPUTY CHIEFS
Chief of Police and Deputy Chiefs of Police
Radio: "Unit" + assigned number
CAD: "U00" + assigned number
Sworn and civilian staff under direction of the Chief of Police or Deputy Chiefs of Police
Radio: "Unit" + assigned three?digit number. The first of the three digits will coincide with the number of the unit to which the staff person is assigned; for example, staff assigned to Unit 1, Chief of Police, will use three-digit numbers ranging from 100?199.
CAD: "U" + assigned three?digit number
PERSONNEL ASSIGNED TO PSCC
PSCC Director
Radio: "COM CENTER 1"
CAD: "CC01"
PSCC Commander, Emergency Operations
Radio: "COM CENTER 2"
CAD: "CC02"
Other Personnel
Radio: "COM CENTER 3" through "COM CENTER 99"
CAD: "CC03" through "CC99"
Emergency Management Office
Radio: "EMO1" through "EMO9"
CAD: "EMO1" through "EMO9"
PERSONNEL IN NON?ASSIGNED STATUS
Any officer below the rank of first lieutenant having a need to use the police radio in a non?assigned status
Radio: "Unit" + EIN
CAD: EIN
Officers ranking first lieutenant and above shall use their assigned designators.
OFF-DUTY LAW ENFORCEMENT EMPLOYMENT
All officers working off-duty law enforcement employment shall use assigned designators as specified in General Order 340, Section V.E.
OTHER AGENCIES
Alcoholic Beverage Control Board
Radio: "ABC1" through "ABC9"
CAD: "ABC1" through "ABC9"
Detox Diversion Teams
Radio: "Detox 1" and "Detox 2"
CAD: "DET1" and "DET2"
Federal Bureau of Investigation (FBI)
Radio: "FBI 10" through "FBI 12"
CAD: "FB10" through "FB12"
Game Wardens
Radio: "GW1" through "GW9"
CAD: "GW01" through "GW09"
Northern Virginia Community College Campus Police Department
Radio: "NOVA 1"
CAD: "NCC1"
Medical Examiner's Office
Radio: "ME1"
CAD: "ME01"
Mobile Crisis
Radio: "Woodburn 1"
CAD: "WB01"
Norfolk Southern Railway Company Police
Radio: "Railroad 1" through "Railroad 3"
CAD: "RR01" through "RR03"
Radio Shop
Radio: "Radio 1" through "Radio 99"
CAD: "RAD1" through "RAD99"
Sheriff's Department
Deputies
Radio: "Sheriff" + assigned EIN
CAD: "S" + assigned EIN
Mt. Vernon Station
Radio: "Lockup" + station number (2) + consecutive number from 0 through 5
CAD: "LU" + "2" + consecutive number from 0 through 5
Mason Station
Radio: "Lockup" + station number (4) + consecutive number from 0 through 5
CAD: "LU" + "4" + consecutive number from 0 through 5
Virginia State Police
CAD: "VSP7"
fireradio
Southwest USA
Thanks. I saw this years ago in my local library's copy of the FCPD SOP's... went back recently to make photo copies and they had removed this section of the SOP.
