Yes, freqhopping is right... someone removed the current control channel from the RRDB and therefore the HP and GRE databases are a week behind (and the RRDB still hasnt been corrected.)
If you dont know anything about manually programming your PSR-800 or an HP-1, you are out of luck for a while. This is a big problem with the database driven scanners!
I think with the PSR-800 you can manually edit the data that comes from the library and is stored in the radio, you cant do that with the HP-1 without making a completely new system in a favorites list.
I am guessing it will be at least a couple weeks before this gets fixed, since the GRE and HP databases are one or two weeks behind RRDB.
