Fairview PD
boycesm
Found that Fairview PD uses CTCSS code of 156.7, not sure where to notify the DB Admin, but figured I'd start here.
DickH
You don't need to use the CTCSS tones unless you are getting interference from another station on the same freq. although there is no harm in adding it to the database.
Is it 154.8225? If so, I wonder how much they use it since they are on the trunk system.
boycesm
Yes it is 154.8225 I can hear it at like 75th & Powell using BCD436HP and 110-450MHz (rough estimate) antenna. can't remember the brand, I'll look it up when I get home.
mikepdx
Corbett, OR USA
I submitted that 154.8225 originally and with an 88.5 PL
after hearing FPD cars there. The 88.5 somehow never made it to the dB.
Are you positive the 156.7 PL is on 154.8225 ?
(Cowlitz SO is very close on 154.815 with a 156.7 tone).
Even though Troutdale and Fairview PD's have their own
dedicated 800 Tacs, the VHF simplex are regularly used when
car-to-car. 154.995 127.3 Troutdale and 154.8225 for Fairview.
