Falls Twp, Bucks Cty
w2xq
Burlington County, NJ
Scanning the 30-50 MHz range midday yesterday for E-layer propagation (none was found), I found what appears to be the fire dispatch on 46.06 MHz. The PL was 94.8, different than the current RRDB listing. Maybe someone in the Levittown-Morrisville area can confirm? HTH.
jje64
My data shows the following:
46.06 East Fire TG PL=97.4 This is/was run by the county
46.06 East Fire TG PL-94.8 This is/was run by the local fire company
Now, I do not regularly listen to the East TG so these may no longer be in use
jje64
I confirmed via monitoring that the 94.8 tone is the correct tone for East Fire TG. I also looked at some old notes and it appears the county has turned off all their Lowband multicasts of the trunksystem. Therefore, I will assume the 97.4 tone is no longer valid
