False location display
catken
I live in White Bear. Why is it on my GRE 800 that is shows WBL fire on the display when the transmissions are coming from Roseville and Maplewood. Confused
catken
False Locations
All I know is that when I programed the scanner that I entered the info. for Maplewood and Roesville .
NDRADIONUT
FARGO ND
When you hear the wrong thing... Make note of the name and freq that shows on the display and i will check into it !
wogggieee
Hugo , MN
You probably have the alpha tag programmed wrong. Double check the talkgroup that you have programmed for WBL.
