errant decodes
All digital communications suffer from some percentage of 'bit errors'. Signal quality is in fact usually measured as "Bit Error Rate" (BER). For wired systems like computer networks, the BER is a very small number, like 1 bit in 10E6 or better. On radio systems the quality's not as good - you can hear that yourself.
So there's two things to do if you want better digital comms: clean up the signal (more transmit power, quieter receiver, eliminate multipath, etc.), or code the data so bit errors can be detected and dealt with. With a scanner, about all you have control of is location and antenna; many posts here talk about the great improvements you might get with an apparently minor change. The error-handling is where Uniden comes in... the scanner is reading a 3600 bit/sec data stream that has some level of error detection available. But it's not very robust and the scanner designers then get to choose what to do with it. (Example: you could wait for ten consecutive matching channel assignments before jumping to the voice channel, but users probably wouldn't like missing the first few seconds of the comms.)
The earliest trunk trackers required you to program ALL the voice channels - that way, if the control instructions were decoded wrong, the scanner most likely would see that it was an invalid frequency and ignore it. Based on experience and some amount of customer input, we now have the option to program only the control channels and take our chances with the occasional erroneous assignment. Most of those go to dead air and immediately return to scanning - in the original problem of this thread, there are only two talkgroups and it's very obvious to the user that the errors occur.
So to say Uniden DMA scanners "have a known problem" is a bit of a stretch. All trunking radios have to deal with this issue, the 396 happens to chase a marginal signal more often than some other scanners and H/Ts that might make fewer mistakes but miss more transmissions completely. Commercial gear can afford more $$ for higher a quality front end tuned to a specific band. I suspect Uniden would respond if there was enough consumer interest in a scanner that performed, and cost, like a high-end Motorola H/T, but I'm putting my money into antennas.
Flash
