I have the portable version of the 996p2, the 325p2. I also have the 436hp, the portable version of the 536hp as you know, and here’s my take on both radios:
- I consider my 325p2 as my local/regional radio, the one I use the most out and about, in my region (let’s say “my county”), with main systems imported from radio reference, and with my own discovered frequencies not in radio reference database.
- I consider my 436hp as my travel radio: lots of useful features for when travelling in little known areas / regions. The zip code feature along with Services selection, makes for a pleasing no fuss listening experience.
So…. I guess it is fair to say that considering your intended use (fixed base station, in a local/regional environment), the 996p2 would fit the bill perfectly.
And if you need to travel, your 436hp will do the job no problem.
The only thing to consider is if you have multicast in your area: you could have difficulty with those systems. But I assume that you already have no problem with the 436, so again yes, the 996p2 seem to fit the bill.
