Recording without a real purpose would put unneccessary write cycles on the SD card, maybe rethink recording everything?That IS good to know and what I was hoping for.
I, obviously, don't use it enough to know that, but I do now!
Thank you!
[ Borderline thread hijack ] I wish there was a top level menu item to 'disable writing to SD card', @JoeBearcat. What exactly gets written on shutdown that is so mission critical anyway?I'll second this. With my first SDS100, I recorded everything, which I eventually figured out contributed to the premature failure of several microSD cards.
I have been recording with my 436 for years and have yet to wear out a Micro SD card. I download them to my PC and review with the Universal
Scanner Player and then delete from the scanner. Why spend $500-700 on a radio and then worry about a $10-15 SD card?
Among other things, if you are using a GPS, it would need to write your location so it doesn't have to wait for a GPS fix on startup. Plus, if you were recording, it would need to finish writing to the card along with insuring all open files are closed.[ Borderline thread hijack ] I wish there was a top level menu item to 'disable writing to SD card', @JoeBearcat. What exactly gets written on shutdown that is so mission critical anyway?
[ /Borderline thread hijack ]
Doesn't the unit inhibit writing to the SD card when it's running without a battery? I'll have to check that when I get home.Among other things, if you are using a GPS, it would need to write your location so it doesn't have to wait for a GPS fix on startup. Plus, if you were recording, it would need to finish writing to the card along with insuring all open files are closed.
According to HowStuffWorks, memory cells in micro SD cards can undergo up to 10,000 write-and-erase cycles before wearing out. Since 10,000 write cycles are the equivalent of writing and erasing the card's content daily for nearly 30 years, memory cards are generally long-lasting.
NoDoesn't the unit inhibit writing to the SD card when it's running without a battery? I'll have to check that when I get home.
Thanks for confirming @donc13, once @RandyKuff mentioned it only inhibited the recording function earlier - it sounded more correct in my head.
It will even have control over files that are never updated and its cells have only been written once, and move that file to cells that have been used the most, to make use of that "fresh" cells. The cells that keep the file allocation table, that will get the most wear, are of another type. I have constant recording enabled in my HP1 and have been so for over 10 years now of at least 5 hours of daily use and still have its original SD card.Write cycles are in the order of 100,000 (Not 10,000) today and SD cards include circuitry to manage wear-leveling, that is, it spreads out writes over the storage media evenly to avoid “hot spots”... Meaning spots being written too frequently and therefore failing early...
