FastNet Site # Change
ATCTech
It appear that site #1.1 we have listed as Milton has changed to site 1.4 sometime recently. Still on 420.500 but the ID has changed. Loaded site 1.1 from the Site Loader and it immediately changed to 1.4. Signal strength & TAFL still has it only 4 or so km away from me here up on Appleby Line.
VA3DBJ
Ontario Database Admin
Durham Region, Ontario
Looks like Toronto has been changed to 2.2
I am getting no signal from the Courtice site. I used to get a weak signal, but nothing now.
Enjoi19
I'm near North Oshawa and tried putting in both frequencies for the Mitchell's Corners site, neither seemed to be coming up. Did a quick scan of 460-465 and only picked up other things (Including I think the Toronto site). Doesn't seem to be active in this region anymore.
ATCTech
Poking around the TAFL, I see that the Toronto license is shown as Federal Wireless Communications, the very company we're discussing in the Niagara Peninsula including the other DMR TIII network the CBSA is using.
Mitchell's Corners is registered to 795395 Ontario Limited, but ONLY the 463.775 frequency as 461.625 MHz that we have listed is not licensed anywhere in Ontario at all now. (The network is comprised of area-specific licensees operating under the FastNet banner.) See more here: FastNet Wireless by Hytera – Enhanced two-way DMR communication network
The coverage map goes right down to Fort Erie, which makes me wonder if the system the CBSA is using will be amalgemated into FastNet over time as we're seeing commercial users on it these days.
VA3DBJ
The 461.625 was licensed until recently to the left over of Williams Communications. The frequency had been playing the usual company shell game until spring of this year. The last time I checked the database it was there until around April, under an Ontario numbered company.
It was running until a couple of months ago. It was a very weak signal or the signal was directly towards Toronto/Niagara.
gary123
Anyone get the current site number for Ballantrae? Both Toronto and Ballantrae are listed as site 2.2
ATCTech
Ballantrae is listed as 3.2, not 2.2... just checked it now and that's still the case using 463.3875 as the prospective CC.
radioman253
Toronto, ON
In DSD fastlane v 2.268 using FMP24 to directly enter freq 420.4625 -
showing Tiii (HYT) Site:L13-2.6
This is a strong signal in the Oshawa area i suspect this and 420.775 have replaced the 463.775 & 461.625.
So far heard school buses in Durham Region on TG 16515088 and ENC activity on TG 16515173
ATCTech
Good catch! And nothing in the TAFL yet other than those frequencies being part of the FWC system in Fort Erie.
mciupa
Moderator
If someone can provide CH ID's we can add them to the database for 2.6
ATCTech
If the calculator is telling me the truth 420.3625 is LSN 77 and 420.775 is LSN 127. If it is telling me the truth then there are LSN issues with a bunch of frequencies as listed for other sites on the system. Updates to follow once I prove the theory...
ATCTech
First, correction to my post #12 regarding the LSN for 420.4625. I see I typed 420.3625, not 420.4625. The LSN stands at 77 from what I can tell as the calculator uses a base frequency of 419.2500 with 419.4750 being LSN 1 (using 12.5 kHz steps in the program). I'm confused about VA3DBJ's post #13. Where did you see a value of 3278 in the 420-421 MHz range? Even if the system used 6.25 kHz steps, frequencies as high as 424 MHz should only have LSNs in the 1200 range and LCNs of half that, no?
VA3DBJ
ATCTech
Out of curiosity, try it with an empty frequency file in DSD+ and see if it detects those channel numbers over the air. Here's site 7 (East Garafraxa) running exactly that way right now. I'm using empty frequency, network, site & site loader files to let the system tell DSD+ what's being sent so there's no chance of data in my files being interpreted as belonging to this system or site. The CC in this case is 422.2625 but there's been no voice traffic seen on the second slot so it hasn't populated yet.
VA3DBJ
Without the req file.
ATCTech
Wow, that's wild! Thanks, and completely out of sorts with the rest of the network channel IDs.
gary123
LOL, Bell does like to mess with stuff. That's my opinion so I'll leave it at that before someone gets mad at me :).
