Hello all!
I have a new to me XPR550e. I received it used, it had R02.23.01.3001 firmware. The previous owner didn't erase the code plug I decided to do a recovery and start with a new code plug. I downloaded and installed the same R02.23.01.3001 firmware. I selected Recover from CPS and it wrote the firmware. However now I have a Fatal Error 01/90 after the radio turns on. I probably made matters worse when I thought something may have just gone wrong with the recovery, so I recovered again, but I used a newer version R02.24.01.1002 firmware from Feb 24. Still have the same Fatal Error. The CPS can read and write from the radio without issue. Also, CPS will not let me downgrade back to the original firmware.
How bad have I screwed this up? Any ideas on how or IF I can recover it?
Thank you for your time!
