kc4jgc
When did public safety make the switch?
Been digital as long as I've had my Pro-106 at least; that's been at least 10 years.
Im stuck (again). Im trying to program a BCD 436HP and the "Lo Channel" and "Hi Channel" is throwing me off. I see Band Plan1 through Band Plan 6 under "Custom". Is this where I enter these settings?This is what you need to program into the system:
Lo Channel----Hi Channel---- Offset----Base Frequency----Step
440------------559------------440--------851.025------------25.0
0---------------719------------0----------851.025------------25.0
720------------759------------0----------848.000------------25.0
815------------931------------0----------846.625------------25.0
958------------958------------958-------868.975------------25.0
961------------1022----------0----------843.400-------------25.0
Thanks!Yes. Here's what I have in a working SDS100:
Band Plan 1
Base: 851.025 Lower, 854.000 Upper
Offset: 440, + Polarity
Spacing: 25.0 kHz
Band Plan 2
Base: 851.0125 Lower, 868.9875 Upper
Offset: 0, + Polarity
Spacing: 25.0 kHz
Dave
Be sure you have the system set as Motorola. Not P25.Im stuck (again). Im trying to program a BCD 436HP and the "Lo Channel" and "Hi Channel" is throwing me off. I see Band Plan1 through Band Plan 6 under "Custom". Is this where I enter these settings?
It may depend on which scanner you are using. A lot of times, there isn't one specific answer that covers all brands and models. You might have your scanner on ID Search instead of ID Scan. Or if you are using a Whistler/GRE/Radio Shack, the equivalent issue is having a Wildcard programmed. That would explain why you are getting services you didn't expect, although it wouldn't explain why you are missing police and fire. Depending on model, you might not have the correct service types selected for monitoring. You may have accidently turned off Law Enforcement and Fire and had Public Utilities and Schools turned on.Hey Guys, I’ve had this system programmed I to my scanner for some time and recently I’m picking up school maintenance and sometimes bus traffic. No talk group is displayed on the scanner at the time. Anything easy I can check, my selected tall groups are all fire and police for Culpeper.
Thanks for the quick replies. I explained my issue wrong, I'm still hearing Police and Fire, but will randomly hear what sounds like bus traffic and today, a lot of building maintenance type users. When I heard this random traffic there is just numbers displayed on the screen, not a talkgroup. I'll try to write it down the next time it happens. The scanner is a BCD996T on ID SEARCH.
