James, do yourself and all of us a favor.
LOAD from the database first. Make a favorites list called VSP STARS and then go into the database and load/ append the channels JUST for VSP into your scanner. Do this to make sure first and foremost you can get the thing working correctly.This has been the problem all a long.
Once you IN FACT can hear VSP STARS on the x36 unit and know it is working then go in and start playing.
Many people have asked you to do this including me and you have been all over the page with settings and ideas. We need to know if you can get things before playing with them...know what I am saying?
Funny you should ask/suggest this.
This is where I had the issue with all the deletion in Sentinel was because of all the STARS sites. I may need to do this again in a different way, but at least I had what appears to be success.
But the STARS issue was not my real issue here.
Here is my side of the STARTS story so far. I have a HP1, 396xt, 996xt and now the 536HP, also have a lot of other radios/scanners as well. I have only had the 536HP for 5 days, so I have not spent a lot of time with it.
As for STARS, did get it working with my 396xt, have not play with it a long time.
The problem for me, in my location, STARTS is very spotty. I have sweet spots and dead zones.
I have STARS programmed on the 536HP at the moment. But the radio is not in a sweet spot, I need to move it to a different location in the house and I will use the telescopic whip I have on a PRO2096 that is receiving STARS reasonably well.
What have noticed is with the 536HP next to me in the "dead" zone, I do not see the signal indicator.
But if I move my hand within 12 inches of the scanner I start to see 2-4 signal bars on the display.
I am on the couch and I am only moving my forearm and hand, less that 12 inches to get within 12 inches of the scanner.
So I must have multipath or there is some strange reflection going on??
Anyway I have a bunch of antennas and even a number or Low Noise Amps I can play with as well.
I can also drive a few miles to higher ground, but in the big scheme of things I am only 2 miles from he state line and I am not sure how good the coverage is here in my area for STARS?
We can take this back to the VSP thread if needed.
My original issue with not with STARS, I would NEVER use that as a baseline acid test, I was playing with Fairfax FD/PD which works quite well, with the exception of simulcast, in my current location within the house.
